[GRASS-dev] BLAS/LAPACK detection (was: configure fails)
Hamish
hamish_nospam at yahoo.com
Mon Oct 1 06:08:48 EDT 2007
Glynn Clements wrote:
> [Actually, I'm not sure that PostgreSQL really belongs on that list.
> When we adopted a policy of generating fatal errors if important
> dependencies were missing, PostgreSQL was the only supported database,
> and it resulted in a bunch of additional pg.* modules as well as
> adding PostgreSQL support to NVIZ.
> Now that other databases can be used, and the option only affects
> compilation of the actual database driver, it could probably be turned
> off by default. OTOH, maybe that should wait for 7.x.]
my vote is for setting the default to --without-postgres now (6.3+).
Hamish
