[GRASS-dev] [grass-code I][495] gis.m output window buttons don't fit text width
Maris Nartiss maris.gis at gmail.com
Mon Oct 1 03:22:17 EDT 2007
just 2 notes:
1) Carlos - when reporting such issues, please, specify language. If
language is know, anyone can test it with "export LC_ALL=es_ES";
2) Michael - for bugreports, please, check it at bug tracker, as
attachments may not be forwarded to ML. Also - any important comments
should be attached to bugreport, as not everyone will search bug
reports AND ML for same issue.
Sorry for interuption,
Maris.
2007/9/30, Carlos Dávila <cdavilam at jemila.jazztel.es>:
> Michael Barton escribió:
> > Carlos,
> > Which buttons? Can you send a screenshot?
> You can see it here:
> http://wald.intevation.org/tracker/download.php/21/204/495/232/Salida%20-%20GIS.m.png
> > Michael
> > NB: It would be nice if the the difficulty of replying to Carlos in this
> > message could be reduced (i.e., not having to manually look up his email
> and
> > paste it in to my reply)
> > On 9/30/07 6:13 AM, "grass-dev at grass.itc.it" <grass-dev at grass.itc.it>
> wrote:
> >> code I item #495, was opened at 2007-09-30 15:13
> >> Status: Open
> >> Priority: 3
> >> Submitted By: Carlos Dávila (carluti)
> >> Assigned to: Nobody (None)
> >> Summary: gis.m output window buttons don't fit text width
> >> Issue type: module bad feature
> >> Issue status: None
> >> GRASS version: CVS HEAD
> >> GRASS component: gis.m
> >> Operating system: Linux
> >> Operating system version: debian testing
> >> GRASS CVS checkout date, if applies (YYMMDD):
> >> Initial Comment:
> >> Translated text within some buttons is larger than default width and text
> is
> >> cut, even if you enlarge the window.
> >> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=495&group_id=21
> > __________________________________________
> > Michael Barton, Professor of Anthropology
> > Director of Graduate Studies
> > School of Human Evolution & Social Change
> > Center for Social Dynamics & Complexity
> > Arizona State University
> > phone: 480-965-6213
> > fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
