[GRASS-dev] ganim troubles in latest cvs
    Kirk Wythers
    kwythers at umn.edu
    Mon Oct  1 13:35:19 EDT 2007
On Oct 1, 2007, at 11:15 AM, Glynn Clements wrote:
> Kirk Wythers wrote:
>> On Sep 30, 2007, at 11:23 PM, Michael Barton wrote:
>>> Well, after asking for help, I figured out how to this without the
>>> dread
>>> regexp ;-). This might even be a bit better routine.
>>> Anyway, I can't commit this because I'm out of town, but if anyone
>>> wants to
>>> try it, you need to change lines in procedure GmAnim::main (module
>>> animate.tcl). Replace the commented lines with the uncommented
>>> lines below.
>>>     foreach line $reglist {
>>>         set line [string trim $line]
>>>         set key [lindex [split $line "="] 0]
>>>         switch $key {
>>>             nsres    {set oldres1 [lindex [split $line "="] 1]}
>>>             ewres   {set oldres2 [lindex [split $line "="] 1]}
>>>             rows    {set vrows [lindex [split $line "="] 1]}
>>>             cols    {set vcols [lindex [split $line "="] 1]}
>>> #     regexp {nsres= *([0-9]+)} $region dummy oldres1
>>> #     regexp {ewres= *([0-9]+)} $region dummy oldres2
>>> #     regexp {rows= *([0-9]+)} $region dummy vrows
>>> #     regexp {cols= *([0-9]+)} $region dummy vcols
> Add:
> 	set reglist [split $region "\n"]
In the foreach loop, like this?
         switch $key {
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
