[GRASS-dev] macosx compilation error in d.m
Tue Oct 2 17:59:46 EDT 2007
Agustin Diez Castillo wrote:
> > Can you clarify? Are you saying that even after "make distclean" and
> > "configure", the problem with d.m.html doesn't always occur?
> No it doesn't, I was clarifying that before the error occurred the
> first time I had done "make distclean".
> Now I can compile with no errors but
> Generated HTML docs in ../dist.i686-apple-darwin8.10.1/docs/html/
> index.html
> Following modules are missing the 'description.html' file in src code:
> d.m
That message indicates that d.m.html was found but is missing the
DESCRIPTION section.
FWIW, I've since changed the way that the HTML files are generated;
pattern rules are no longer used. I don't know if this will actually
fix the problem, though.
