[GRASS-dev] macosx compilation error in d.m
Agustin Diez Castillo
Agustin.Diez at uv.es
Tue Oct 2 10:51:04 EDT 2007
> Can you clarify? Are you saying that even after "make distclean" and
> "configure", the problem with d.m.html doesn't always occur?
No it doesn't, I was clarifying that before the error occurred the
first time I had done "make distclean".
Now I can compile with no errors but
Generated HTML docs in ../dist.i686-apple-darwin8.10.1/docs/html/
Following modules are missing the 'description.html' file in src code:
d.m
GRASS GIS compilation log
Started compilation: Tue Oct 2 15:59:30 CEST 2007
Errors in:
No errors detected.
> Glynn Clements <glynn at gclements.plus.com>
