[GRASS-dev] macosx compilation error in d.m
Michael Barton michael.barton at asu.edu
Mon Oct 1 23:23:16 EDT 2007
I've had this problem for ages. I just cd to the d.m directory and type
make. Then all is well. A bit annoying, but not a problem. I probably
shouldn't even bother with this.
Michael
On 10/1/07 1:53 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> Same problem here.  After distclean, I get the no target error.  dist/
> scripts/d.m is created, but not dist/docs/html/d.m.html.  Immediately
> running make -C gui/tcltk/d.m again succeeds and installs d.m.html.
> make clean, then make - back to the error.
> PS. Augustin, I found and fixed a macosx build problem (a couple
> hours ago) from Glynn's parallel build updates.  You should do a cvs
> update or you won't get a OSX app.
> On Oct 1, 2007, at 2:07 PM, Agustin Diez Castillo wrote:
>> On Oct 1, 2007, at 8:38 PM, Glynn Clements wrote:
>>> Can you please try the following:
>>> 1. Delete the files:
>>> dist.i686-apple-darwin8.10.1/docs/html/d.m.html
>> it does exist
>>> dist.i686-apple-darwin8.10.1/scripts/d.m
>> it does exist
>>> gui/tcltk/d.m/d.m.tmp.html
>> it doesn't exist
>>> 2. Run "make -C gui/tcltk/d.m"
>>> 3. Report any errors, and whether any of the files mentioned in #1
>>> above exist.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly
> disappear and be replaced by something even more bizarrely
> inexplicable.  There is another theory which states that this has
> already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
