[GRASS-dev] [grass-code I][497] r.spread not working
grass-dev at grass.itc.it
Tue Oct 2 07:27:45 EDT 2007
code I item #497, was opened at 2007-10-02 13:27
Status: Open
Priority: 3
Submitted By: Ljiljana Bodrozic (ljiljana)
Assigned to: Nobody (None)
Summary: r.spread not working
Issue type: module bug
Issue status: None
GRASS version: 6.1
GRASS component: None
Operating system: None
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
In grass vesions higher then 6.0 r.spread module for wildfire spread modeling is not working (freezes)
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=497&group_id=21
