[GRASS-dev] [grass-code I][495] gis.m output window buttons don't fit text width
Carlos Dávila cdavilam at jemila.jazztel.es
Tue Oct 2 11:30:06 EDT 2007
Michael Barton escribió:
> Carlos,
> May I suggest that "run (background)" might be better translated as
> "ejecutar (fondo)" than "ejecutar (segundo plan)" This should fit OK.
I think "Segundo plano" is better translation than "fondo" in this case,
but anyway you gave me an idea for the solution (2º plano), so thanks.
Next question is what may happen in other languages.
Carlos
