[GRASS-dev] another make problem (OSX, but could be a general problem)
William Kyngesburye woklist at kyngchaos.com
Tue Oct 2 14:34:35 EDT 2007
On Oct 2, 2007, at 12:30 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>>> A couple of questions:
>>> 1. Is this with a MacOSX App build? If so, do you get the same
>>> behaviour with a non-App build?
>> Actually, yes.  Before I fixed a small problem where the macosx dir
>> didn't build, it was happening.
> Is that "yes" to the first or to the second, or both?
> If this only happens with the App build, then it's (mainly) up to you
> to solve. I can't test an App build, and it appears to be modifying
> some of the *.make files.
> For now, I'm only interested in issues which occur when using the
> stock build system (i.e. no --enable-macosx-app).
yes, without OSX app build - all that is really is just another
subdir to make, so the libraries and modules are all stock GRASS.
>>> 2. Does it help if you change the following in Rules.make from:
>>> $(OBJDIR)/%.o : %.c $(LOCAL_HEADERS) | $(OBJDIR)
>>> 	$(CC) $(CFLAGS) $(EXTRA_CFLAGS) $(NLS_CFLAGS) $(EXTRA_INC) $(INC) \
>>> 		-o $(OBJDIR)/$*.o -c $*.c
>>> to:
>>> 	$(MKDIR) $(OBJDIR)
>> Much better.
> Is the "make" program GNU make? Does it come via Apple? Can you try
> building GNU make from the stock source package and using that?
> Prerequisites listed to the right of "|" are "order-only"; if
> necessary, they will be built before the target, but they won't cause
> the target to be re-compiled.
> If you're using something other than GNU make (which includes modified
> versions if the modifications make a difference), then I can't really
> help. I would rather not unconditionally run mkdir for every object
> file if it's an issue with one particular make program.
OSX Tiger/GCC 4 uses GNU Make 3.80.  It doesn't look like Apple
modified it (like they have for other stuff).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly
what the universe is for and why it is here, it will instantly
disappear and be replaced by something even more bizarrely
inexplicable.  There is another theory which states that this has
already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
