[GRASS-dev] another make problem (OSX, but could be a general problem)
William Kyngesburye woklist at kyngchaos.com
Wed Oct 3 15:54:18 EDT 2007
On Oct 3, 2007, at 1:10 PM, Glynn Clements wrote:
> A "user" won't care about incremental rebuilds not actually being
> incremental. They'll "configure; make; make install" then not compile
> it again (at least, not without [dist]clean first).
True.  If it's unfixable, I can keep using the current up-to-date
make.  We'd have to recommend to other devs to update their make.
>> And, since Markus had the same problem, there may be Linux distros
>> that have an older make in their package manager.
> I missed that.
http://grass.itc.it/pipermail/grass-dev/2007-October/033237.html
> Note the vertical bar is missing from yours. Can you try the same
> thing with a module (which doesn't re-compile everything)?
It's also missing the pipe:
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20071003/2846342c/makedb_mod.txt.zip
I preceded the pipe with a backslash in Rules.make - now it keeps the
pipe and libraries aren't recompiled.  But, this doesn't work in
3.81, so it doesn't look like a usable solution.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
