[GRASS-dev] another make problem (OSX, but could be a general problem)
Thu Oct 4 07:53:58 EDT 2007
William Kyngesburye wrote:
> > Note the vertical bar is missing from yours. Can you try the same
> > thing with a module (which doesn't re-compile everything)?
> It's also missing the pipe:
It's missing, but that case *doesn't* recompile everything? Ugh; this
is getting confusing.
> I preceded the pipe with a backslash in Rules.make - now it keeps the
> pipe and libraries aren't recompiled.  But, this doesn't work in
> 3.81, so it doesn't look like a usable solution.
Okay, how about this:
# default cc rules
ifeq ($(MAKE_VERSION),3.81)
$(OBJDIR)/%.o : %.c $(LOCAL_HEADERS) | $(OBJDIR)
	$(CC) $(CFLAGS) $(EXTRA_CFLAGS) $(NLS_CFLAGS) $(EXTRA_INC) $(INC) \
		-o $(OBJDIR)/$*.o -c $*.c
else
	$(MAKE) $(OBJDIR)
endif
This is less than ideal, as it will revert to the old form for 3.82,
but I can't think of a simple way to check for >= 3.81 (especially
considering that the version might not actually be a number, e.g.
3.81-r1 or similar).
