[GRASS-dev] r.neighbors help file
twiens
twiens at interbaun.com
Fri Oct 5 20:53:50 EDT 2007
----- Original Message Follows -----
To: Trevor Wiens <twiens at interbaun.com>
Cc: grass-dev at grass.itc.it
Subject: Re: [GRASS-dev] r.neighbors help file
Date: Sat, 6 Oct 2007 01:19:52 +0100
> Trevor Wiens wrote:
> > > > I noticed that the options listed in the help are
> > > > based odd number up to 25. However, at least with
> > > > the 6.3 cvs version, any value is accepted and in
> > > > looking at the code there is not apparent reason
> larger values shouldn't work. I tried it and it seems to
> > > > run fine and accurately with values of 31 or 35.
> > > > Am I missing something or does the help page need to
> > > be updated?
> > > Fixed in CVS.
> > I just checked
http://www.grass.itc.it/grass63/manuals/html63_user/r.neighbors.html
> > and found the following text in the options section of
> > the help page.
> > Neighborhood Size: The neighborhood size specifies which
> > cells surrounding any given cell fall into the
> > neighborhood for that cell. The size must be an odd
> > integer. Options are: 1, 3, 5, 7, 9, 11, 13, 15, 17, 19,
> 21, 23, and 25. For example,
> Yes; that's the part that I've just fixed in CVS (the
> description.html file).
> The online documentation is taken from the weekly builds,
> so it will take up to a week before the latest change
> appears online.
Sorry Glynn, just my ignorance showing again.
Thanks for fixing it.
T
Trevor Wiens
