[GRASS-dev] r.neighbors help file
Scott Mitchell
smitch at mac.com
Fri Oct 5 20:22:00 EDT 2007
On 5 Oct 2007, at 18:40, Trevor Wiens wrote:
> On Fri, 5 Oct 2007 23:23:57 +0100
> Glynn Clements <glynn at gclements.plus.com> wrote:
>> Trevor Wiens wrote:
>>> I noticed that the options listed in the help are based odd
>>> number up
>>> to 25. However, at least with the 6.3 cvs version, any value is
>>> accepted and in looking at the code there is not apparent reason
>>> larger values shouldn't work. I tried it and it seems to run fine
>>> and
>>> accurately with values of 31 or 35.
>>> Am I missing something or does the help page need to be updated?
>> Fixed in CVS.
> I just checked
> http://www.grass.itc.it/grass63/manuals/html63_user/r.neighbors.html
> and found the following text in the options section of the help page.
> Neighborhood Size: The neighborhood size specifies which cells
> surrounding any given cell fall into the neighborhood for that
> cell. The size must be an odd integer. Options are: 1, 3, 5, 7, 9,
> 11, 13, 15, 17, 19, 21, 23, and 25. For example,
It just needs time to propagate - Glynn has changed the
description.html in the source directory for that module to read:
"The neighborhood <EM>size</EM> specifies which cells surrounding any
given
cell fall into the neighborhood for that cell.
For example," ...
The web site is built from the CVS tree once per day (if I recall
correctly), unless Markus manually runs the update script. Therefore
it will take a while before the correction shows up on grass.itc.it,
and then perhaps another day before it shows up mirror sites.
Apologies if I've missed your point...
Scott
