[GRASS-dev] r.neighbors help file
Glynn Clements
glynn at gclements.plus.com
Fri Oct 5 20:19:52 EDT 2007
Trevor Wiens wrote:
> > > I noticed that the options listed in the help are based odd number up
> > > to 25. However, at least with the 6.3 cvs version, any value is
> > > accepted and in looking at the code there is not apparent reason
> > > larger values shouldn't work. I tried it and it seems to run fine and
> > > accurately with values of 31 or 35.
> > > Am I missing something or does the help page need to be updated?
> > Fixed in CVS.
> I just checked
> http://www.grass.itc.it/grass63/manuals/html63_user/r.neighbors.html
> and found the following text in the options section of the help page.
> Neighborhood Size: The neighborhood size specifies which cells
> surrounding any given cell fall into the neighborhood for that cell.
> The size must be an odd integer. Options are: 1, 3, 5, 7, 9, 11, 13,
> 15, 17, 19, 21, 23, and 25. For example,
Yes; that's the part that I've just fixed in CVS (the description.html
file).
The online documentation is taken from the weekly builds, so it will
take up to a week before the latest change appears online.
