[GRASS-dev] r.neighbors help file
Trevor Wiens twiens at interbaun.com
Fri Oct 5 18:40:23 EDT 2007
On Fri, 5 Oct 2007 23:23:57 +0100
Glynn Clements <glynn at gclements.plus.com> wrote:
> Trevor Wiens wrote:
> > I noticed that the options listed in the help are based odd number up
> > to 25. However, at least with the 6.3 cvs version, any value is
> > accepted and in looking at the code there is not apparent reason
> > larger values shouldn't work. I tried it and it seems to run fine and
> > accurately with values of 31 or 35.
> > Am I missing something or does the help page need to be updated?
> Fixed in CVS.
I just checked
http://www.grass.itc.it/grass63/manuals/html63_user/r.neighbors.html
and found the following text in the options section of the help page.
Neighborhood Size: The neighborhood size specifies which cells surrounding any given cell fall into the neighborhood for that cell. The size must be an odd integer. Options are: 1, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23, and 25. For example,
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
