[GRASS-dev] r.neighbors help file
Fri Oct 5 18:23:57 EDT 2007
Trevor Wiens wrote:
> I noticed that the options listed in the help are based odd number up
> to 25. However, at least with the 6.3 cvs version, any value is
> accepted and in looking at the code there is not apparent reason
> larger values shouldn't work. I tried it and it seems to run fine and
> accurately with values of 31 or 35.
> Am I missing something or does the help page need to be updated?
Fixed in CVS.
