[GRASS-dev] OK to compile on Mac?
Michael Barton michael.barton at asu.edu
Mon Oct 8 01:13:14 EDT 2007
I had no problem compiling, except the normal d.m error.
Michael
On 10/7/07 2:07 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> There is no problem in the actual compiling.  The problem is the old
> make on OSX will recompile *everything* after a successful make if
> you run make again (like you might do when you modify a source file,
> but then you could make individual modules to avoid recompiling
> everything).
> On Oct 7, 2007, at 3:48 PM, Michael Barton wrote:
>> William
>> I've been sort of following your work with Glynn to improve Mac
>> compiling. If I compile from CVS today, will it work OK as before
>> or am I likely to run into trouble?
>> Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly
> disappear and be replaced by something even more bizarrely
> inexplicable.  There is another theory which states that this has
> already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
