[GRASS-dev] OK to compile on Mac?
Glynn Clements
glynn at gclements.plus.com
Sun Oct 7 19:51:56 EDT 2007
William Kyngesburye wrote:
> There is no problem in the actual compiling. The problem is the old
> make on OSX will recompile *everything* after a successful make if
> you run make again (like you might do when you modify a source file,
> but then you could make individual modules to avoid recompiling
> everything).
Actually, the current CVS version of Rules.make contains the check for
"ifeq ($(MAKE_VERSION),3.81)", so that shouldn't occur.
OTOH, there may be some inefficiency with make versions other than
3.81, as it will attempt to create $(OBJDIR) (via a recursive make
invocation) for each object file.
