[GRASS-dev] Python swig
Trevor Wiens twiens at interbaun.com
Mon Oct 8 23:16:52 EDT 2007
I was having troubles getting the python swig interfact to install from my cvs build.
I found the following. Making successfully in the swig/python dir and then run make install from the cvs root dir didn't copy the necessary files to the proper destinations. I had to copy these myself by hand.
Second, it wouldn't work on my ubuntu fiesty system because like 6.10 stack protection is set is set to on. So I had to add the following flag to the Make file: -fno-stack-protector to get it to compile into a form that was useable on my system.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
