[GRASS-dev] Python swig
Tue Oct 9 06:33:31 EDT 2007
Trevor Wiens wrote:
> I was having troubles getting the python swig interfact to install from my
> cvs build.
> I found the following. Making successfully in the swig/python dir and then
> run make install from the cvs root dir didn't copy the necessary files to the
> proper destinations. I had to copy these myself by hand.
> Second, it wouldn't work on my ubuntu fiesty system because like 6.10 stack
> protection is set is set to on. So I had to add the following flag to the
> Make file: -fno-stack-protector to get it to compile into a form that was
> useable on my system.
you might have a look at the following thread, AFAIK several of the 'make'
issues raised in it have still not been fixed.
  http://thread.gmane.org/gmane.comp.gis.grass.devel/20751
Hamish
____________________________________________________________________________________
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
