[GRASS-dev] gis.m symbol error in cvs
Maris Nartiss maris.gis at gmail.com
Fri Oct 12 02:25:13 EDT 2007
You are right. It's broken.
Guilty lines - 199/227 at
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/gtcltk/select.tcl.diff?r1=1.18&r2=1.19
Seems, that we need to go back to old, (ugly) code, if nobody comes up
with better solution. See attached patch. Somebody test && commit.
Maris.
2007/10/12, Trevor Wiens <twiens at interbaun.com>:
> On two systems I've tried, choosing point symbols results in a format of
> box at basic
> instead of
> basic / box
> As a result, the display of points fails
> T
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20071012/8b8fc8d6/select_symbol.bin
