[GRASS-dev] gis.m symbol error in cvs
Trevor Wiens twiens at interbaun.com
Fri Oct 12 18:22:25 EDT 2007
On Fri, 12 Oct 2007 09:25:13 +0300
"Maris Nartiss" <maris.gis at gmail.com> wrote:
> Hi,
> You are right. It's broken.
> Guilty lines - 199/227 at
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/gtcltk/select.tcl.diff?r1=1.18&r2=1.19
> Seems, that we need to go back to old, (ugly) code, if nobody comes up
> with better solution. See attached patch. Somebody test && commit.
I tested it locally and it works on my one system ( I don't have access to the other today ). I don't have cvs access so I can't commit it.
> Maris.
> 2007/10/12, Trevor Wiens <twiens at interbaun.com>:
> > On two systems I've tried, choosing point symbols results in a format of
> > box at basic
> > instead of
> > basic / box
> > As a result, the display of points fails
> > T
> > Trevor Wiens
> > The significant problems that we face cannot be solved at the same
> > level of thinking we were at when we created them.
> > (Albert Einstein)
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
Trevor Wiens
(Albert Einstein)
