[GRASS-dev] GRASS 6.2.2: gis.m crashes when there are more than one map with same name in path
Moritz Lennert mlennert at club.worldonline.be
Fri Oct 12 13:16:39 EDT 2007
Hello,
I don't know if this is a problem with just my installation (compiled
Debian 6.2.2 package with source code from Debian site) but it seems
that that an important bug which (AFAIK) is fixed in 6.3, is still
present in 6.2.2:
In spearfish:
1) g.copy vect=fields at PERMANENT,fields
2) Select 'fields' as vector file to display and in Map Display "Zoom to
selected map".
=> gis.m crashes and in terminal you see:
WARNING: 'vector/fields' was found in more mapsets (also found in user1).
If another bugfix release of 6.2 is foreseen can this be backported ?
Moritz
