[GRASS-dev] GRASS 6.2.2: gis.m crashes when there are more than
one map with same name in path
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 16 05:16:07 EDT 2007
Re-launching this question since we will begin GIS classes soon with
6.2.2 and I would like to resolve this before.
Can someone confirm this bug ? If yes, could someone point me to the fix
in 6.3, so that I can at least locally backport it to 6.2.2 ?
Thanks,
Moritz
On 12/10/07 19:16, Moritz Lennert wrote:
> Hello,
> I don't know if this is a problem with just my installation (compiled
> Debian 6.2.2 package with source code from Debian site) but it seems
> that that an important bug which (AFAIK) is fixed in 6.3, is still
> present in 6.2.2:
> In spearfish:
> 1) g.copy vect=fields at PERMANENT,fields
> 2) Select 'fields' as vector file to display and in Map Display "Zoom to
> selected map".
> => gis.m crashes and in terminal you see:
> WARNING: 'vector/fields' was found in more mapsets (also found in user1).
> If another bugfix release of 6.2 is foreseen can this be backported ?
> Moritz
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
