[GRASS-dev] GRASS 6.2.2: gis.m crashes when there are more
than one map with same name in path
Markus Neteler
neteler at itc.it
Tue Oct 16 05:40:00 EDT 2007
Moritz,
no big deal to make a 6.2.3 release.
I am afraid that you need to use gdb or ddd (see Wiki for instructions)
to debug a bit.
Markus
On Tue, Oct 16, 2007 at 11:16:07AM +0200, Moritz Lennert wrote:
> Re-launching this question since we will begin GIS classes soon with
> 6.2.2 and I would like to resolve this before.
> Can someone confirm this bug ? If yes, could someone point me to the fix
> in 6.3, so that I can at least locally backport it to 6.2.2 ?
> Thanks,
> Moritz
> On 12/10/07 19:16, Moritz Lennert wrote:
> > Hello,
> > I don't know if this is a problem with just my installation (compiled
> > Debian 6.2.2 package with source code from Debian site) but it seems
> > that that an important bug which (AFAIK) is fixed in 6.3, is still
> > present in 6.2.2:
> > In spearfish:
> > 1) g.copy vect=fields at PERMANENT,fields
> > 2) Select 'fields' as vector file to display and in Map Display "Zoom to
> > selected map".
> > => gis.m crashes and in terminal you see:
> > WARNING: 'vector/fields' was found in more mapsets (also found in user1).
> > If another bugfix release of 6.2 is foreseen can this be backported ?
> > Moritz
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
