[GRASS-dev] native WinGRASS and attribute data deadlock, next try
Markus Neteler neteler at itc.it
Sun Oct 14 10:42:28 EDT 2007
Moritz Lennert-2 wrote:
> On Mon, October 8, 2007 22:46, Moritz Lennert wrote:
>> On Sun, October 7, 2007 23:04, Glynn Clements wrote:
>>> Could someone familiar with DBMI and vectors test it out?
>> Rapid testing in Debian (v.out/in.ogr, v.univar, d.vect.thematic, g.copy)
>> with dbf, sqlite, postgres does not show any problems. Will test in
>> windows as soon as I solve the compile problems.
> Compile problems in windows are not solved, yet (see other mail), but they
> should not interfere with the dbmi issues. Rapid testing in windows also
> confirms that everything seems to work fine.
> I propose to commit to CVS to allow further testing.
This is excellent! And hopefully still comes in time for the upcoming
QGIS release (which tells us that we should get out 6.3.0 to avoid
a moving target for them!).
Markus
View this message in context: http://www.nabble.com/Re%3A-native-WinGRASS-and-attribute-data-deadlock%2C-next-try-tf4461552.html#a13199672
Sent from the Grass - Dev mailing list archive at Nabble.com.
