[GRASS-dev] Unable to see v.edit tools description
Martin Landa
landa.martin at gmail.com
Wed Oct 17 04:54:22 EDT 2007
2007/10/17, Carlos Dávila <cdavilam at jemila.jazztel.es>:
> There's an entry in grassmods that describes tools that can be used in
> v.edit in the form: tool1;Tool 1 description;tool2;Tool 2 description...
> I have tried to see this information using the module, but I'm not able.
> Can anyone tell how to display it?
Not sure if I understand well your question. You mean?
$ v.edit help
tool Tool
options: create,add,delete,copy,move,flip,catadd,catdel,merge,
break,snap,connect,vertexadd,vertexdel,vertexmove,zbulk,
select
create: Create new (empty) vector map
add: Add new features to existing vector map
delete: Delete selected features from vector map
copy: Copy selected features
move: Move selected features in vector map
flip: Flip direction of selected vector lines
catadd: Set new categories to selected vector featurs for
defined layer
catdel: Delete categories from selected vector features
for defined layer
merge: Merge selected vector lines
break: Break (split) vector line into two separate lines
snap: Snap vector features in given threshold
connect: Connect two lines
vertexadd: Add new vertex to selected vector lines
vertexdel: Remove vertex from selected vector lines
vertexmove: Move vertex of selected vector lines
zbulk: Z bulk-labeling (automated assignment of z
coordinate to vector lines)
select: Select lines and print their ID's
Well in Tcl/Tk dialog I didn't find it, for wxPython GUI I will fix it...
> Regards
> Carlos
Martin
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
