[GRASS-dev] Unable to see v.edit tools description
Carlos Dávila
cdavilam at jemila.jazztel.es
Thu Oct 18 10:31:21 EDT 2007
Martin Landa escribió:
> Hi,
> 2007/10/17, Carlos Dávila <cdavilam at jemila.jazztel.es>:
>> There's an entry in grassmods that describes tools that can be used in
>> v.edit in the form: tool1;Tool 1 description;tool2;Tool 2 description...
>> I have tried to see this information using the module, but I'm not able.
>> Can anyone tell how to display it?
> Not sure if I understand well your question. You mean?
> $ v.edit help
> tool Tool
> options: create,add,delete,copy,move,flip,catadd,catdel,merge,
> break,snap,connect,vertexadd,vertexdel,vertexmove,zbulk,
> select
> create: Create new (empty) vector map
> add: Add new features to existing vector map
> delete: Delete selected features from vector map
> copy: Copy selected features
> move: Move selected features in vector map
> flip: Flip direction of selected vector lines
> catadd: Set new categories to selected vector featurs for
> defined layer
> catdel: Delete categories from selected vector features
> for defined layer
> merge: Merge selected vector lines
> break: Break (split) vector line into two separate lines
> snap: Snap vector features in given threshold
> connect: Connect two lines
> vertexadd: Add new vertex to selected vector lines
> vertexdel: Remove vertex from selected vector lines
> vertexmove: Move vertex of selected vector lines
> zbulk: Z bulk-labeling (automated assignment of z
> coordinate to vector lines)
> select: Select lines and print their ID's
> Well in Tcl/Tk dialog I didn't find it, for wxPython GUI I will fix it...
Thanks Martin, that's what a needed.
Carlos
