[GRASS-dev] i18N guisection bug
Markus Neteler
neteler at itc.it
Thu Oct 18 03:26:43 EDT 2007
Maris,
thanks but I am afraid that the bug persists.
To test:
export LANG=de_DE
export LANGUAGE=de_DE
export LC_ALL=de_DE
g.region
bad window path name ".nb.fGebe_für_Shell-Skript-Weiterverwendung_aus"
Markus
Maris Nartiss-2 wrote:
> Hi,
> it comes from wrong regexp in gui.tcl file. Attached patch fixes problem.
> Maris.
> 2007/10/17, Markus Neteler <neteler at itc.it>:
>> We discovered that both 6.2 and 6.3 fail in DE locale when starting
>> for example g.region:
>> bad window path name ".nb.fGebe_für_Shell-Skript-Weiterverwendung_aus."
>> while executing
>> "winfo reqwidth $path.f$page"
>> (procedure "compute_size" line 9)
>> invoked from within
>> "compute_size $path"
>> (procedure "NoteBook::_realize" line 7)
>> invoked from within
>> "NoteBook::_realize .nb"
>> (command bound to event)
>> The related .po file contains:
>> general/g.region/cmd/main.c:136
>> msgid "Print;Shell Script"
>> msgstr "Gebe für Shell-Skript-Weiterverwendung aus."
>> and the source code:
>> flag.gprint = G_define_flag();
>> flag.gprint->key = 'g';
>> flag.gprint->description = _("Print in shell script style");
>> flag.gprint->guisection = _("Print;Shell Script");
>> Questions:
>> - is it correct to apply _() gettext macros to >guisection?
>> - if so, how to avoid this bug with accented characters/umlauts?
>> This potentially affects many modules.
>> Markus
>> View this message in context:
>> http://www.nabble.com/i18N-guisection-bug-tf4642555.html#a13260519
>> Sent from the Grass - Dev mailing list archive at Nabble.com.
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
> Index: lib/gis/gui.tcl
> RCS file: /home/grass/grassrepository/grass6/lib/gis/gui.tcl,v
> retrieving revision 2.23
> diff -u -u -r2.23 gui.tcl
> --- lib/gis/gui.tcl 6 Oct 2007 21:13:47 -0000 2.23
> +++ lib/gis/gui.tcl 17 Oct 2007 21:11:53 -0000
> @@ -713,7 +713,7 @@
> # Replace all non-ascii chars, spaces, $ and braces in path with
> undescore
> - set path [regsub -all {[][{}\$\s\u0100-\uffff]} $path "_"]
> + set path [regsub -all
> {[][{}\$\s\u007a-\uffff\u0001-\u002d\u005b-\u0060]} $path "_"]
> set root [expr {$path == "" ? "." : $path}]
> set opt($dlg,path) $path
> set opt($dlg,root) $root
View this message in context: http://www.nabble.com/i18N-guisection-bug-tf4642555.html#a13269454
