[GRASS-dev] make on SMP
Maciej Sieczka tutey at o2.pl
Mon Oct 22 12:32:36 EDT 2007
Markus Neteler wrote:
> Glynn Clements wrote:
>> The reason I left NVIZ alone until now
>> was that the Makefiles were a mess. Although I fixed some obvious
>> problems, I may have introduced some new ones while cleaning up.
> I tried NVIZ 3 times with -j3 and twice with -j4, no problem.
> Compiling GRASS twice with -j4: no problem!
> Both on RHEL5.
4 build from scratch tries here on Ubuntu Dapper 64bit. One
of them failed as follows (full logs at [1]):
GRASS GIS compilation log
Started compilation: Mon Oct 22 09:41:40 CEST 2007
Errors in:
/home/maciek/src/straight/grass63/lib/vector/diglib
In case of errors please change into the directory with
error and run 'make'.If you get multiple errors, you need to
deal with them in the order they appear in the error log. If
you get an error building a library, you will also get
errors from anything which uses the library.
Finished compilation: Mon Oct 22 09:45:20 CEST 2007
make: *** [default] Error 1
Maciek
[1]http://www.biol.uni.wroc.pl/sieczka/udostepnione/grass/grass63_make_j3_22.10.07.tar.bz2
