[GRASS-dev] make on SMP
Mon Oct 22 14:16:34 EDT 2007
Maciej Sieczka wrote:
> >> The reason I left NVIZ alone until now
> >> was that the Makefiles were a mess. Although I fixed some obvious
> >> problems, I may have introduced some new ones while cleaning up.
> > I tried NVIZ 3 times with -j3 and twice with -j4, no problem.
> > Compiling GRASS twice with -j4: no problem!
> > Both on RHEL5.
> 4 build from scratch tries here on Ubuntu Dapper 64bit. One
> of them failed as follows (full logs at [1]):
> GRASS GIS compilation log
> Started compilation: Mon Oct 22 09:41:40 CEST 2007
> Errors in:
> /home/maciek/src/straight/grass63/lib/vector/diglib
--- lib/vector/diglib/Makefile	23 Sep 2007 07:07:55 -0000	1.26
+++ lib/vector/diglib/Makefile	22 Oct 2007 18:15:32 -0000
@@ -40,7 +40,8 @@
 TEST = $(OBJDIR)/test
-default: lib $(TEST)
+default: lib
+	$(MAKE) $(TEST)
 #  Test portable read/write functions
 $(OBJDIR)/test: test.c $(DEPENDENCIES) $(ARCH_LIB_OBJS)
