[GRASS-dev] Re: problem with G_fatal_error
Martin Dobias wonder.sk at gmail.com
Wed Oct 24 17:17:26 EDT 2007
On 10/24/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> > Even better would be to make a list of GRASS functions which could end
> > with fatal error. Now it's fixed only for that particular know case
> > where it was terminating QGIS, but I guess there might be more such
> > functions...
> The list would be most of GRASS.
> E.g. G_malloc() calls G_fatal_error() if malloc() fails (although you
> probably can't handle that case anyhow). Anything which uses the
> environment (database, location, mapset, etc) will fail if $GISRC
> isn't set, can't be opened, doesn't contain correct data, etc.
> It might (literally) be simpler to list functions which can't call
> G_fatal_error().
Ah, so in that case we should use setjmp() before (nearly) every call
to GRASS routine, which is not a way to go. Thus I think we'll stick
with using setjmp() explicitly only at places known to produce fatal
errors. Or are there some more possibilities?
Martin
