[GRASS-dev] GRASS 6.3.0RC1 released
Carlos Dávila cdavilam at jemila.jazztel.es
Wed Oct 24 17:19:55 EDT 2007
Glynn Clements escribió:
> Carlos Dávila wrote:
>>>> I looked at your announcement for the 6.3 release. It is excellent. I
>>>> noticed several new modules that have been missed in the menu and need to be
>>>> added. Can I just add them to the current grass6 cvs source I've been
>>>> working with for 6.3 or do I need to check out another source tree for a
>>>> release branch to add them?
>>> Add them to the head first, then back-port to the release branch after
>>> testing.
>>> The quickest way to get the release branch is to make a copy of the
>>> head (cp -a) then run "cvs update -r releasebranch_6_3" in the copy.
>>> To sync changes from the trunk to a branch, use "cvs update" with two
>>> -j switches, e.g.:
>>> 	cvs update -j releasebranch_6_3 -j HEAD
>>> This is roughly equivalent to:
>>> 	cvs diff -r releasebranch_6_3 -r HEAD | patch -p0
>> I followed your instructions to send some changes to both head and
>> release branch. Files were updated in my local releasebranch copy, but
>> doesn't seem to have changed in repository (or I'm looking in the wrong
>> place).
> Both of the above only update the local copy; you need to use
> "cvs commit" to actually commit the changes.
Yes, but the problem is I did "cvs ci" from releasebranch copy and it
did nothing.
