[GRASS-dev] some backports to 6.3.0-CVS branch
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Thu Oct 25 12:29:05 EDT 2007
Hmmm, I am getting an error trying to compile the vector lib
on MingW now:
cd lib/vector/
make
make -C rtree || echo /src/grass6/lib/vector/rtree >> /src/grass6/error.log
make[1]: Entering directory `/src/grass6/lib/vector/rtree'
make[1]: *** No rule to make target
`/src/grass6/dist.i686-pc-mingw32/include/grass/rtree/card.h', needed by
`lib'.  Stop.
make[1]: Leaving directory `/src/grass6/lib/vector/rtree'
make -C dglib || echo /src/grass6/lib/vector/dglib >> /src/grass6/error.log
make[1]: Entering directory `/src/grass6/lib/vector/dglib'
make[1]: Leaving directory `/src/grass6/lib/vector/dglib'
make -C diglib || echo /src/grass6/lib/vector/diglib >>
make[1]: Entering directory `/src/grass6/lib/vector/diglib'
make OBJ.i686-pc-mingw32
make[2]: Entering directory `/src/grass6/lib/vector/diglib'
make[2]: `OBJ.i686-pc-mingw32' is up to date.
make[2]: Leaving directory `/src/grass6/lib/vector/diglib'
gcc -I/src/grass6/dist.i686-pc-mingw32/include -I/usr/include -g -O2
-I/usr/include     -DPACKAGE=\""grasslibs"\" -I/usr/include
-DPACKAGE=\""grasslibs"\"  -I/src/grass6/dist.i686-pc-mingw32/include -o
OBJ.i686-pc-mingw32/allocation.o -c allocation.c
In file included from
C:/msys/1.0/src/grass6/dist.i686-pc-mingw32/include/grass/vect/digit.h:3,
                 from
C:/msys/1.0/src/grass6/dist.i686-pc-mingw32/include/grass/Vect.h:4,
                 from allocation.c:22:
C:/msys/1.0/src/grass6/dist.i686-pc-mingw32/include/grass/vect/dig_structs.h:18:25:
grass/rtree.h: No such file or directory
make[1]: *** [OBJ.i686-pc-mingw32/allocation.o] Error 1
make[1]: Leaving directory `/src/grass6/lib/vector/diglib'
make -C Vlib || echo /src/grass6/lib/vector/Vlib >> /src/grass6/error.log
make[1]: Entering directory `/src/grass6/lib/vector/Vlib'
make[2]: Entering directory `/src/grass6/lib/vector/Vlib'
make[2]: Leaving directory `/src/grass6/lib/vector/Vlib'
-DPACKAGE=\""grasslibs"\"   -DPACKAGE=\""grasslibs"\"
-I/src/grass6/dist.i686-pc-mingw32/include -o OBJ.i686-pc-mingw32/area.o
-c area.c
                 from
                 from area.c:20:
make[1]: *** [OBJ.i686-pc-mingw32/area.o] Error 1
make[1]: Leaving directory `/src/grass6/lib/vector/Vlib'
make -C transform || echo /src/grass6/lib/vector/transform >>
make[1]: Entering directory `/src/grass6/lib/vector/transform'
make[1]: Leaving directory `/src/grass6/lib/vector/transform'
My sources are a few hours old. When did you commit these changes?
Could they be the cause of my troubles?
Cheers,
Benjamin
Markus Neteler wrote:
> Hi,
> I have backported recent fixes/license updates to the
> new release branch except for
> - basename
> - r.out.tiff
> - new Vect_*() changes
> Just tell me if I should or not. If course I don't mind
> if you backport directly (which is yet easy).
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
