[GRASS-dev] some backports to 6.3.0-CVS branch
Glynn Clements
glynn at gclements.plus.com
Thu Oct 25 17:01:42 EDT 2007
Benjamin Ducke wrote:
> Hmmm, I am getting an error trying to compile the vector lib
> on MingW now:
> cd lib/vector/
> make
> make -C rtree || echo /src/grass6/lib/vector/rtree >> /src/grass6/error.log
> make[1]: Entering directory `/src/grass6/lib/vector/rtree'
> make[1]: *** No rule to make target
> `/src/grass6/dist.i686-pc-mingw32/include/grass/rtree/card.h', needed by
> `lib'. Stop.
The rule should be there in the Makefile:
RTLINC = $(ARCH_INCDIR)/rtree
$(RTLINC)/%.h: %.h | $(RTLINC)
$(INSTALL_DATA) $< $@
> My sources are a few hours old. When did you commit these changes?
> Could they be the cause of my troubles?
The last update to lib/vector/rtree was:
RCS file: /grassrepository/grass6/lib/vector/rtree/Makefile,v
Working file: Makefile
head: 1.10
branch:
locks: strict
access list:
keyword substitution: kv
total revisions: 10; selected revisions: 1
description:
revision 1.10
date: 2007/10/19 13:45:53; author: glynn; state: Exp; lines: +12 -14
Only install grass<ver>.bat on Windows (MinGW)
Fix Windows build problems with d.frame, v.voronoi
Fix (?) parallel build problems with lib/vector/rtree and lib/gpde
Avoid trying to "install" lib/gis/colors/CVS directory
The there are no differences between the trunk, 6.3 release branch,
and 6.3-RC1 for lib/vector/rtree.
