[GRASS-dev] Python script problem
Glynn Clements
glynn at gclements.plus.com
Thu Oct 25 17:11:51 EDT 2007
monik1982\@libero\.it wrote:
> Hello everybody,
> I'm new to python and I'm trying to build up a script...
> When I run the script the only commands that are executed are
> cmdargs1= ["elevation=%s" %dtm]
> cmdargs2=["slope=slope1", "format=percent", "--overwrite"]
> os.execvp("r.slope.aspect", ["r.slope.aspect"] + cmdargs1 + cmdargs2)
> The other commands are ignored...What can be the issue?
os.execvp() doesn't return (unless it fails); it executes the
specified command *in place of* the script which calls it.
If you want to run a command without terminating the script, use
subprocess.Popen as suggested by Michael. For more details, see §17.1
of the Python library reference:
http://docs.python.org/lib/module-subprocess.html
In most scripts, the only place where os.execvp() should be used is
for invoking g.parser.
