[GRASS-dev] G_check_input_output() and fully qualified output map
name
Martin Landa
landa.martin at gmail.com
Mon Oct 29 07:09:23 EDT 2007
Hi all,
I realized a strange behaviour of r.buffer, e.g.
$ r.buffer in=e out=e d=1
No error, input and output is the same...
$ r.buffer in=e out=e at user1 d=1
Illegal filename. Character <@> not allowed.
ERROR: <e at user> is an illegal file name
Why so restrictive? The current mapset is 'user1'.
I modified library function G_check_input_output() to handle also this case.
If mapset defined for output map is not the current one:
ERROR: Mapset defined for output map <e at user> is not the current mapset
Any objects to commit to CVS?
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20071029/4d410112/legal_name.bin
