[GRASS-dev] [grass-code I][524] d.vect.thematic // mysql: data-type
problem
grass-dev at grass.itc.it
Wed Oct 31 15:24:16 EDT 2007
code I item #524, was opened at 2007-10-31 15:24
Status: Open
Priority: 3
Submitted By: Michael Ash (mash)
Assigned to: Nobody (None)
Summary: d.vect.thematic // mysql: data-type problem
Issue type: module bug
Issue status: None
GRASS version: 6.2.2
GRASS component: vector
Operating system: Linux
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
I am having some problems with data types trying to map thematic data from a mysql database table.
Here is the table:
Field Type Null Key Default Extra
cat int(11) YES NULL
AREA double YES NULL
PERIMETER double YES NULL
BG25_D00_ double YES NULL
BG25_D00_I double YES NULL
STATE varchar(2) YES NULL
COUNTY varchar(3) YES NULL
TRACT varchar(6) YES NULL
BLKGROUP varchar(1) YES NULL
NAME varchar(90) YES NULL
LSAD varchar(2) YES NULL
LSAD_TRANS varchar(50) YES NULL
ToxConc2003 double YES NULL
lToxConc2003 double YES NULL
latino decimal(16,5) YES NULL
black decimal(16,5) YES NULL
poor decimal(26,5) YES NULL
AND HERE IS THE COMPLAINT FROM GRASS:
v.info -c map=bg25_d00 layer=1
Displaying column types/names for database connection of layer 1:
MySQL driver: column 'latino', type 246 is not supported
MySQL driver: column 'black', type 246 is not supported
MySQL driver: column 'poor', type 246 is not supported
INTEGER|cat
DOUBLE PRECISION|AREA
DOUBLE PRECISION|PERIMETER
DOUBLE PRECISION|BG25_D00_
DOUBLE PRECISION|BG25_D00_I
CHARACTER|STATE
CHARACTER|COUNTY
CHARACTER|TRACT
CHARACTER|BLKGROUP
CHARACTER|NAME
CHARACTER|LSAD
CHARACTER|LSAD_TRANS
DOUBLE PRECISION|ToxConc2003
DOUBLE PRECISION|lToxConc2003
I can probably resolve this by setting the type to DOUBLE in MySQL, but d.vect.thematic should accept DECIMAL's. I have also had problems with type FLOAT.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=524&group_id=21
