[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output
map names
Maciej Sieczka
tutey at o2.pl
Sat Sep 1 06:06:49 EDT 2007
Brad Douglas wrote:
> I started working on this awhile ago after realizing values were
> hardcoded, etc. IIRC, I didn't finish because it was becoming
> complicated and I didn't have time to dedicate to it.
> I can commit what I have (and comment unfinished code) if someone
> wants to have it done relatively quickly and is willing to finish it
> themselves.
> Until then, I think it should probably be removed from the Makefile.
I have committed the documenation clean up. Things still unclear
> On Wed, 2007-08-29 at 00:16 +0700, Yann wrote:
>> Yes, this is test data, was in testdata/ dir in the grassSVN
>> Add-ons before joining CVS.
>> Please anyone with write access may change this. Yann
>> On Tuesday 28 August 2007 03:41:17 grass-dev at grass.itc.it wrote:
>>> code I item #470, was opened at 2007-08-27 22:41 Status: Open
>>> Priority: 3 Submitted By: Maciej Sieczka (msieczka) Assigned to:
>>> Nobody (None) Summary: i.atcorr: hardcoded input/output map
>>> names Issue type: module bug Issue status: None GRASS version:
>>> CVS HEAD GRASS component: imagery Operating system: None
>>> Operating system version: GRASS CVS checkout date, if applies
>>> (YYMMDD): 070827
>>> Initial Comment: i.atcorr has a follwoing set of map names
>>> hardcoded:
>>> iimg=ETM4_400x400.raw ialt=dem_float ivis=visibility
>>> icnd=ETM4_atmospheric_input_GRASS.txt oimg=6s_output_file
>>> Shouldn't have any.
