[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Sep 2 07:11:34 EDT 2007
Hello Maris
On Sun, 2 Sep 2007, Maris Nartiss wrote:
> Sorry for jumping-in.
> I may be not following hard enough, but I just tested error catching
> in lib/init/file_option.tcl proc fileOpt::create_loc and it works in
> both cases:
> 1) Try to create new location from GDAL unsupported file -> outputs
> g.proj error;
> 2) Move all GDAL libs to some other place and then try to create new
> location -> outputs "shared library not found" error.
> IMHO both of them are most common errors and having reported to user
> in some user-friendly way is good thing. Any other common problem that
> should be tested?
Yes I think it works quite well there. I copied some of what you did in
file_option.tcl for my recent improvements to epsg_option.tcl. The way I
see it is that because the catch function takes an optional argument - a
variable to catch whatever is written to stderr - there is no need to
redirect stderr to a file. In effect we use the catch command to "catch"
the stderr output.
DialogGen works well for popping up clear error messages with the same
look and file as the rest of the GUI (in fact I changed it so the border
on the OK button looks the same as the other buttons in gis_set.tcl and
associated dialogs). tk_messageBox (on Windows anyway) resulted in a
dialog box with a totally different look and feel and to me at least it
seemed a bit inconsistent in regard to which windows it popped up in front
of. I wouldn't recommend using it - I changed a couple of occurences of it
in epsg_option.tcl to use DialogGen instead.
Paul
