[GRASS-dev] GRASS printing
William Kyngesburye
woklist at kyngchaos.com
Wed Sep 5 10:14:04 EDT 2007
On Sep 5, 2007, at 1:17 AM, Michael Barton wrote:
> I did some experimentation with the lpr part of mapprint.tcl
> tonight. I'm
> thinking that maybe I've done this before and come up with the same
> result--and that is why I turned to ghostscript.
> TclTk will output to a PS file that looks just fine when I open it.
> However, just sending this to lpr (>>lpr file.ps) gives a very poor
> result.
> The map is up against the upper right edges of the page, rather
> than being
> centered. It is clipped on all edges but the bottom and clipped a
> significant amount on the left side of the map (a side which is NOT
> against
> the edge of a page).
> Is there something I'm missing in sending this to lpr?
> Michael
What about job options? The CUPS manual has better documentation
than the lpr man page. Check http://localhost:631/documentation.html.
A mismatch of the document orientation and the job orientation can
cause odd clipping. And default position is probably upper-left, but
again orientation can cause trouble, rotation said upper left to
another corner.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people
of the allied nations devoted an entire year exclusively to hating
the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
