[GRASS-dev] Re: GRASS printing
Michael Barton
michael.barton at asu.edu
Wed Sep 5 11:08:58 EDT 2007
The options described in the CUPS docs may be what I need. Thanks.
Michael
On 9/5/07 7:14 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> On Sep 5, 2007, at 1:17 AM, Michael Barton wrote:
>> I did some experimentation with the lpr part of mapprint.tcl
>> tonight. I'm
>> thinking that maybe I've done this before and come up with the same
>> result--and that is why I turned to ghostscript.
>> TclTk will output to a PS file that looks just fine when I open it.
>> However, just sending this to lpr (>>lpr file.ps) gives a very poor
>> result.
>> The map is up against the upper right edges of the page, rather
>> than being
>> centered. It is clipped on all edges but the bottom and clipped a
>> significant amount on the left side of the map (a side which is NOT
>> against
>> the edge of a page).
>> Is there something I'm missing in sending this to lpr?
>> Michael
> What about job options? The CUPS manual has better documentation
> than the lpr man page. Check http://localhost:631/documentation.html.
> A mismatch of the document orientation and the job orientation can
> cause odd clipping. And default position is probably upper-left, but
> again orientation can cause trouble, rotation said upper left to
> another corner.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is
> over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people
> of the allied nations devoted an entire year exclusively to hating
> the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
