[GRASS-dev] [grass-web I][475] Version numbers inconsistent
grass-dev at grass.itc.it
Thu Sep 6 21:41:15 EDT 2007
web I item #475, was opened at 2007-09-07 01:41
Status: Open
Priority: 3
Submitted By: Iuri Gavronski (iuri_gavronski)
Assigned to: Nobody (None)
Summary: Version numbers inconsistent
Issue status: None
Site section: Download
Site timestamp (YYMMDD):
Initial Comment:
I am trying to download Windows GRASS using Cygwin setup, using the instructions on
http://grass.itc.it/grass62/binary/mswindows/
but the download fails.
Looking at the files listing: grass-6.2.2-2.cygwin.tar.bz2
Looking at the setup.ini:
@ grass
sdesc: "GRASS - Geographic Resources Analysis Support System"
category: Database
requires: cygwin gdal libintl8 libiconv2 freetype2 libpng12 fftw3 libncurses8 proj readline libtiff5 xterm xorg-x11-base lesstif tcltk-grass
version: 6.2.2-1
install: grass-6.2.2-1.cygwin.tar.bz2 16313625 5506d382b1e1b010b66677cb99991bb8
The last number is different on the file on setup.ini and the file that is actually on the directory.
Please update setup.ini
Thanks.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=210&aid=475&group_id=21
