[GRASS-dev] Re: [grass-code I][481] v.db.connect -p always reports for layer 1 only
Maciej Sieczka tutey at o2.pl
Sun Sep 9 11:38:05 EDT 2007
>> Comment By: Martin Landa (martinl)
> Parameter 'layer' is completely ignored during printing. It
> means *all* available connections are printed, which I think make
> sense. Maybe the module description is not so clear.
Thanks for the information. Yes, module description is not clear.
> For GRASS7 maybe it would be good to add parameter
> "option=add,delete,print"
> For 'add' you need map,driver,database,table,key,layer For 'delete'
> you need map,layer For 'print' just map
Maciek
