[GRASS-dev] animation missing pnmscale
Sun Sep 9 20:18:43 EDT 2007
William Kyngesburye wrote:
> These are the ones I've found so far (searching for 'netpbm'):
> ppmtompeg: r.out.mpeg
This is bound to require some kind of external tool, be it ppmtompeg,
mencoder (from mplayer), etc.
> pngtopnm: d.out.gpsdrive
This is gratuitous. The PNG file is generated by the PNG driver, which
can generate PPM files by itself. Moreover, the ability to generate
PPM files is unconditional, while generating PNG files is optional
(using --without-png will disable it). The "PNG driver" name is a
historical artifact.
> pnmtojpeg: d.out.gpsdrive
This will require an external utility, but "cjpeg" would have been a
better choice. "cjpeg" is built and installed along with libjpeg,
which pnmtojpeg requires. IOW, if you have pnmtojpeg, you already have
cjpeg, but the reverse isn't true.
> pnmscale: xganim.tcl
xganim.tcl was something I hacked together in an hour to determine the
feasibility of replacing xganim. AFAICT, it isn't actually part of
GRASS (yet).
