[GRASS-dev] g.mlist as C implementation?
Hamish
hamish_nospam at yahoo.com
Wed Sep 12 06:47:58 EDT 2007
> - The script relies on "echo -n"; not portable?
Instead of "echo -n" to build the output map by map, what if a string was
constructed within the loop like:
if [ $first ] ; then
OUTSTRING="$MAPNAME$MAPSET"
else
OUTSTRING="$OUTSTRING$SEP$MAPNAME$MAPSET"
fi
and then at end of the script just a single
echo "$OUTSTRING"
is that going to max out at 4096 chars?
what should a the C flat 'g.list -g' output look like? how about:
[user1]
map1
map2
map3
[PERMANENT]
map_a
map_b
map_c
Hamish
