[GRASS-dev] g.mlist as C implementation?
Martin Landa
landa.martin at gmail.com
Wed Sep 12 07:22:20 EDT 2007
2007/9/12, Hamish <hamish_nospam at yahoo.com>:
> what should a the C flat 'g.list -g' output look like? how about:
> [user1]
> map1
> map2
> map3
> [PERMANENT]
> map_a
> map_b
> map_c
BTW, I tried to implement something similar in the past...
g.list rast ncols=1
raster files available in mapset <elev>:
dem_reggio_10
dem_reggio_10_fp
raster files available in mapset <PERMANENT>:
MASK
elev_reggio
elev_reggio_10
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070912/a70f78f4/g-list-ncols.obj
