[GRASS-dev] installed makefile cleanup
William Kyngesburye
woklist at kyngchaos.com
Sat Sep 22 17:53:56 EDT 2007
On Sep 22, 2007, at 3:28 PM, William Kyngesburye wrote:
> This works mostly. The compilation works. But html.make is having
> problems - running the module to generate the htmldesc complains
> about GISDBASE not being set and all I get is the description and
> no module options/usage.
> GISDBASE is set correctly in .grassrc63 in the demolocation I
> installed. Setting a higher DEBUG level doesn't give me any
> helpful info.
Oops. When I edited the demolocation .grassrc63, I accidentally
replaced the : with an = for the GISDBASE setting. It works now.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
