[GRASS-dev] installed makefile cleanup
Glynn Clements
glynn at gclements.plus.com
Sun Sep 23 05:48:23 EDT 2007
William Kyngesburye wrote:
> I started looking at the installed makefile fragments to get them in
> working order to build addons.
Note that I've just committed a bunch of changed to fix the issues
which I mentioned in my previous email.
I'm mainly interested in building for
> external installation, so I'm doing a separate INST_XTN setup based
> on the existing INST_NOW (which builds into the GRASS installation).
> This is what I have so far (all tests, nothing in CVS yet):
> - first, a problem with INST_NOW. In Grass.make, the first: target has:
> first: pre default
> @if test -n "$(INST_NOW)" ; then \
> $(MAKE) inst_now ; \
> fi
> then there is an inst_now: target:
> inst_now:
> INST_NOW= $(MAKE)
> That got into a nasty infinite loop for me when used as suggested:
> make GRASS_HOME=. MODULE_TOPDIR=/Applications/GRASS-6.3.app/Contents/MacOS INST_NOW=y
Right; AFAICT, it needs to be passed as an environment variable, i.e.
"INST_NOW=y make".
If it is given as an argument, it will override any setting in the
Makefile, which will cause an infinite loop.
> So I ignored that for creating my INST_XTN variation.
> - installed a copy of demolocation in the installed GRASS.
> edited .grassrc63 to set GISDBASE to the INST_DIR.
> - Grass.make - add below the "ifdef INST_NOW" block:
> ifdef INST_XTN
> ARCH_DISTDIR = $(INST_DIR)
> XTN_DISTDIR = $(GRASS_HOME)/dist.$(ARCH)
> ARCH_INC = -I$(ARCH_DISTDIR)/include -I$(XTN_DISTDIR)/include
> ARCH_LIBPATH = -L$(ARCH_LIBDIR) -L$(XTN_DISTDIR)/lib
> BIN = $(XTN_DISTDIR)/bin
> ETC = $(XTN_DISTDIR)/etc
> DRIVERDIR = $(XTN_DISTDIR)/driver
> DBDRIVERDIR = $(XTN_DISTDIR)/driver/db
> endif
Regarding the last four, this is the wrong approach. It will break
everytime someone adds another variable for a subdirectory.
It appears that GISBASE needs to be split into source and destination
variables. The former would be used for -I/-L switches, the latter for
determining where to place output files.
> I needed to split ARCH_DISTDIR, which points to the installed GRASS,
> from the distdir for building the extension into. So, that required
> a few other changes in the other makefile frags:
> - platform.make - replace the RUN_GISBASE setting:
> ifdef INST_XTN
> RUN_GISBASE = $(INST_DIR)
> else
> RUN_GISBASE = /Users/Shared/src/GRASS/cvs/grass6/dist.i686-
> apple-darwin8.10.1
> endif
If GISBASE is split appropriately, it shouldn't be necessary to
conditionalise this.
> - html.make - conditionally refer to ARCH_DISTDIR or XTN_DISTDIR as
> needed:
Ditto.
> htmlgen:
> @$(MODULE_TOPDIR)/tools/mkhtml.sh $(PGM)
> -if [ "${INST_XTN}" = "y" ] ; then \
> $(MKDIR) $(XTN_DISTDIR)/docs/html ; \
> mv -f $(PGM).tmp.html $(XTN_DISTDIR)/docs/html/$(PGM).html ; \
> else \
> $(MKDIR) $(ARCH_DISTDIR)/docs/html ; \
> mv -f $(PGM).tmp.html $(ARCH_DISTDIR)/docs/html/$(PGM).html ; \
> fi
> -for file in *.png *.jpg ; do \
> head -n 1 $$file | grep '^#!' > /dev/null ; \
> if [ $$? -ne 0 ] ; then \
> $(INSTALL_DATA) $$file $(XTN_DISTDIR)/docs/html ; \
> else \
> $(INSTALL_DATA) $$file $(ARCH_DISTDIR)/docs/html ; \
> fi \
> fi \
> done 2> /dev/null ; true
> - install tools/mkhtml.sh in the installed GRASS
> This works mostly. The compilation works. But html.make is having
> problems - running the module to generate the htmldesc complains
> about GISDBASE not being set and all I get is the description and no
> module options/usage.
> GISDBASE is set correctly in .grassrc63 in the demolocation I
> installed.
Does $(GISRC) actually refer to that file, though?
