[GRASS-dev] Installing GRASS on cygwin
Duffy, Garret gduffy at nrcan.gc.ca
Thu Sep 27 14:33:39 EDT 2007
I'm having issues installing GRASS on cygwin running on Windows.
I execute the configure script below successfully and with no errors.
CFLAGS="-g -Wall" ./configure  --with-includes=c:/msys/local/include \
--with-libs=c:/msys/local/lib  --with-python
--with-proj-share=/usr/share/proj
But when I run make, it hangs when it enters the d.ask command:
make[2]: Entering directory `/c/GRASS/grass-6.2.2/display/d.ask'
GISRC=/c/GRASS/grass-6.2.2/dist.i686-pc-cygwin/demolocation/.grassrc62
GISBASE=/c/GRASS/grass-6.2.2/dist.i686-pc-cygwin
PATH=/c/GRASS/grass-6.2.2/dist.i686-pc-cygwin/bin:$PATH
PATH="/c/GRASS/grass-6.2.2/dist.i686-pc-cygwin/lib:./:/usr/local/grass-6
.2.2/bin_extra:/usr/local/gr
ass-6.2.2/bin_tcl:/usr/local/bin:/usr/bin:/b
in:/usr/X11R6/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbe
m:/c/Pro
gram Files/ATI Technologies/ATI Control Panel:/c/Program
Files/Reflection:/c/arcgis/arcexe9x/bin:/c/PROGRA~1/COMMON~1/DHI/MikeZer
o:/c/Program
Files/GnuWin32/bin:/usr/local/gmt/bin:/c/Program Files/Common
Files/DHI/MIKEZero:/c/Program Files/QuickTime/QTSystem/:/c/Program
Files/Attachmate/Reflection/:/usr/local/bin:/usr/X11R6/bin:/usr/bin:/c/P
rogram
Files/wgrib" LC_ALL=C /c/GRASS/grass-6.2.2/dist.i686-pc-cygwin/bin/d.ask
--html-description | grep -v '</body>\|</html>' > d.ask.tmp.html ; true
I would be really grateful if anyone could help as I've wasted 2 days
trying
to fix this.  Thanks,
Garret.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070927/9355b2e6/attachment.html
